Engine Shutdown Special Input
Hi
The Forklift is shutting down after approx 10mins work!
with the display showing "Engine Shutdown Special Input"
We know if you it shuts down (after 10min) if the throttle pedal is not operated.
If the throttle is held at high tick over it does not shut down!
Can anyone tell us what controls the "Engine shutdown special input"?
Can anyone point us in the direction may be causing this?
Thanks
  • Posted 16 Jun 2015 01:00
  • By nigel_p
  • joined 8 Jul'10 - 20 messages
  • Worcestershire, United Kingdom
nigel@pandhlifttrucks.co.uk
Sounds like a low oil pressure or over temp shut down.
  • Posted 19 Jun 2015 07:58
  • By BREWSKI
