Exide Depth Chargers
I'm having a problem with several newer Exide SCR chargers. They blow input ( AC ) fuses. I've been through the normal diagnosis, correct fuse rating, correct input voltage and settings, tested the line voltage ( 480v 3ph ) and monitered all 3 legs for variences. Anyone else having issues?
  • Posted 22 Jan 2008 10:09
  • By roadtek
  • joined 4 Dec'07 - 123 messages
maybe type of fuse is wrong for your supply.you can get slowblow fuse. i had problem with rating of rcd breakers in the past. charger i got supplied kept triping out but changed rcd from type B to type D ,same rating and problem went away.
  • Posted 23 Jan 2008 07:52
  • By kevin_k
Had a set blow last week.Wired 208.I sthought someone plugged wrong battery into charger.They have only been wired for 1 month
  • Posted 22 Jan 2008 21:41
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
December 03, 2025 - New Delhi, India
RAEDER-VOGEL
