Check Engine Light
I have a customer that has just purchased a Doosan G30e-5 Serial # MC-00128. In cold weather it started to miss at first acceleration. We changed the spark plugs and corrected that issue. The check engine light stays on continuously and we can't locate any information on how to retrieve the error codes or any procedure to clear check engine light. Any help would be greatly appreciated.
  • Posted 18 Mar 2015 01:37
  • By gw_e
  • joined 18 Mar'15 - 22 messages
hi kevin
have you some of the error codes ? think its flashing 471
kind regards
richard
  • Posted 14 Oct 2023 04:01
  • By richard_m
  • joined 11 Apr'13 - 112 messages
  • lancashire, United Kingdom
richardsforklifts @gmail.com
Hi kevin please could you tell me the sequence to retrive error codes.
the engine sounds like its missing and lumpy
  • Posted 4 Apr 2023 20:09
  • By richard_m
Please could you share as I have the same problem
  • Posted 4 Apr 2023 17:09
  • By richard_m
I have a G33E-5 with an Engine Management Light also staying on. Would you be so kind as to share how you retrieve error codes for this truck.
  • Posted 28 Sep 2018 01:05
  • By GarySW1
  • joined 14 Aug'16 - 11 messages
  • Suffolk, United Kingdom
Yes, it does have a Woodward fuel system. Thanks, that sounds like just what I need. Are there any lists of error code descriptions for these trucks available. I was hoping it was an OBDII compatible forklift, but not so lucky. Thanks, if you could add that procedure, I would greatly appreciate it. I added a email address in my profile.
  • Posted 19 Mar 2015 09:19
  • By gw_e
Have an e,mail to post in your PROFILE? Does this truck have a woodward fuel sytem? There is a procedure using the Accel pedal to retrieve and erase codes.
  • Posted 18 Mar 2015 04:47
  • By kevin_t
Hyster
