What motor is in this forklift?
The water pump has gone out and I don't know what motor is in this to get a replacement water pump from the auto parts store.
  • Posted 1 Feb 2015 05:46
  • By alan_k
  • joined 10 Sep'10 - 4 messages
  • Indiana, United States
Sir what size are tires for this model
  • Posted 16 Aug 2023 07:42
  • By Josh_Milton
  • joined 16 Aug'23 - 1 message
J milton
If it's a Mazda, now would be the time to replace the timing belt, tensioner and idler in addition to the water pump.
Engine family is the same as that used in Mazda B2000 and B2200 trucks. Quite a bit of interchange.
That being said, even though the water pump from a B2000 might bolt on, the impeller could very well be different and not give the flow characteristics you need for a low RPM forktruck engine. Make sure you confirm they are the same.
  • Posted 5 Feb 2015 07:02
  • By Beeker
  • joined 27 Sep'12 - 32 messages
MAZDA ENGINE would be the FE or F2 engine
  • Posted 1 Feb 2015 06:26
  • By kevin_t
Is Going to be either a MAZDA M4-20 engine or a GM 3.0L if distributor is on left side while,sitting,on truck is the GM if is on the right is the MAZDA.....
  • Posted 1 Feb 2015 06:24
  • By kevin_t
Esie Cortez Esie Cortez
Oxford Ct, United States
