code on start up
Have error code 29448 service required on start up. Any ideas how to clear etc not familiar with the small electric stuff.
  • Posted 21 Jan 2015 01:17
  • By oldywan
  • joined 20 Jan'13 - 21 messages
  • Saskatchewan, Canada
If its broke it can be fixed
1. Ensure the steer handle is in the full vertical position at truck startup.
2. Ensure the steer handle enable switch is not being held closed at truck startup.
a. Adjust switch.
b. Verify 0 volts at pin #6 at the controller connector with the steer handle in the vertical position.
3. Measure continuity across pin #1 and pin #2 at the steer handle enable connector.
a. Switch should be open with no continuity shown.
- Replace switch.
  • Posted 3 Mar 2015 14:45
Fault code 29448 is telling you that the control handle is not in full upright position when unit is first turned on. Leave handle alone until after key is first turned on and does self test. Then pull down on handle and use unit. If it continues to fault after trying this, then switch may be out of adjustment, but I doubt it.
  • Posted 3 Mar 2015 11:07
  • By geoff_g
  • joined 23 Jan'15 - 12 messages
Deborah Baker Deborah Baker
Toyota 02-8FD30
SNORKEL A46JE
