NO POWER
lost power nothing show on the display battery is good only 2 moths check all fuses are good all wire connctors ok can sone help please
thank's
  • Posted 9 Jan 2015 01:35
  • By GUANAJUATO
  • joined 3 Jan'15 - 67 messages
  • Illinois, United States
Glad you found it.
  • Posted 10 Jan 2015 07:49
  • By rogeriwt
thank's for the tip found the problem it was one of the 40 amp fuse the was bad look good tested good but no good,,,,
  • Posted 9 Jan 2015 14:09
  • By GUANAJUATO
the display has 2 connectors at the bottom. There are fingers on the circuit plate that contact the connectors and they have been known to come apart. You have to remove the display to see it.
  • Posted 9 Jan 2015 12:04
  • By rogeriwt
Muncie, IN, United States
Kai von Berg Kai von Berg
