Code 211
Truck shuts off while driving full speed. Shows code 211. Battery has full charge.also would like location of solenoid that might be dropping out
  • Posted 6 Dec 2014 01:59
  • By dan_o
  • joined 13 Sep'14 - 15 messages
  • New Jersey, United States
Dan O
211 is SVA open ckt but if error only appear while truck is in full speed, try also to check all power cables especially in access3 and drive motor. Check also your traction encoder or try to replace if problem remains unsolved.
  • Posted 18 Jan 2015 05:26
  • By anonimous06
  • joined 18 Jan'15 - 4 messages
  • laguna, Philippines
211 is SVA open ext cricuit code. Most likely wiring issue. SVA is located on your hydraulic manifold. Test it in Analyzer (A4.4) and meter for B+ & B-
  • Posted 6 Dec 2014 03:53
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
Sue Tomic Sue Tomic
