error code 65
Hi guys I have error code on a komatsu FB15-2R s/n f14016t00028
the error code is error 65 ( Acc out of range ) I have checked to see if the accelerator switch is sticking and it ain't. and can't find any more info to fault find the problem so any help will be good :)
thanks julian
  • Posted 20 Nov 2014 06:40
  • By julls24
  • joined 8 Oct'13 - 2 messages
  • united kingdom, United Kingdom
I am stuck with one of Komatsu Forklift. It is giving Error 69 on the Display unit and Steering Symbol also shown on the Display unit and hence the Steering motor is not allowed to turn the wheels. What is this Error code 69 stands on Komatsu Forklifts.
  • Posted 24 Nov 2014 19:24
  • By sivakumar_a
  • joined 24 Nov'14 - 1 message
  • Dubai, United Arab Emirates
Hey Julis, I believe that it is something else.
FE65, Wire breakage at the output for the electro-magnetic brake
When the brake is driven (clocked), the LAS module monitors this clocking process, i.e. the continuous 1/0 change is checked internally at output X10.3 (closed brake circuit, no wire breakage).
If this is not the case, the system recognises this as wire breakage. The LAS module stops issuing the "Brake released" signal (X10.23) to the FPS. This means that travel is blocked.
Check the wiring and brake (see "LAS module, Checking the electro-magnetic brake").
I'll this will help you further
Regards
Marc b
  • Posted 24 Nov 2014 03:24
  • By marcb
  • joined 10 Jun'14 - 221 messages
  • ANTWERP, Belgium
Taylor T650L
Maxlion FB25LI
