No Start
We have a Nissan powered Tcm lift. no power to the lockoff. The relay that controls that circuit is getting power from the ECM.
But the circuit is not completed to GRD.?I have checked the relays, wiring ,lpg driver.???this truck had a dead battery at the time of failure, but I do not know which came first. the no start or the dead battery. It now cranks good and I have check all physical grds. Any help or leads would be appreciated Ray
  • Posted 18 Nov 2014 04:30
  • By ray_j
  • joined 22 Aug'14 - 13 messages
  • Missouri, United States
Grant89, presently the truck is up and running. It seems that any time the lift has a low or dead battery issue with excessive overcranking it takes out the LPG driver. This time a coil blew backfeeding into the ECM and taking the ECM out. I have completely disassembled the wire harness and made sure all grounds are intack. Our people here will crank one to death just to find out its out of LPG --- go figure--- Thanks for the interested and throw out your thoughts--- I am a good listener Ray
  • Posted 15 Mar 2016 04:50
  • By ray_j
Are you still having issues with this truck
  • Posted 12 Mar 2016 08:53
  • By grant89
  • joined 2 Jul'09 - 28 messages
  • Minnesota, United States
Hi Ray,
FG25N4 TCM - Engine Nissan H20PU41 ??
Checking email...
Best Regards
  • Posted 19 Nov 2014 00:12
  • Modified 19 Nov 2014 03:57 by poster
  • By stefano_tcm
  • joined 25 Oct'14 - 109 messages
  • ITALIA, Italy
TCM Forklift spare parts
tcmricambi@gmail.com
I have a link I use, but cant send pdfs from the link ??(copyrights)It was given to me from local TCM dealer.
  • Posted 19 Nov 2014 00:02
  • By ray_j
Do you have a pdf of the schematic for this TCM you can send me,email is in profile,want to see what is diffrent between this and the other K21/25 schematics i have maybe a diffrent setup than the others....?
  • Posted 18 Nov 2014 06:10
  • By kevin_t
main crank relay ,traced wires directly back to this relay. swapped with known good relays. K25-L I do have access to pin test and schematic. This relay also runs the lpg assist solenoid, which is also not working. It does get power at turn of switch, but is not completed to grd---which appears to be in the crank sensor or the ECM??? Thanks Ray
  • Posted 18 Nov 2014 05:57
  • By ray_j
What nissan engine is installed in this truck....is it the K21/25 Nissan engine?? What relay is it that you are checking????
  • Posted 18 Nov 2014 04:45
  • By kevin_t
Sue Tomic Sue Tomic
