Hydraulics heat up
Once the hydraulics heat up, if you tilt back the entire truck shudders and knocks, but only after the hydraulics heat up to me is an excessive amount the hydraulic tank is actually hot to the touch but if you let the truck cool down the tilt function is fine both ways only acts up after the system heats up if you will
  • Posted 7 Nov 2014 07:59
  • By grant89
  • joined 2 Jul'09 - 28 messages
  • Minnesota, United States
Sounds like restriction in hyd system,check hyd filter, suction and return filter
  • Posted 26 May 2015 09:37
  • By edward_m
  • joined 11 May'15 - 111 messages
Muncie, IN, United States
