Test Track OR Proving Track
I got in to a project in which we have to establish a new test track OR proving track for Material Handling Equipments like forklift, stacker, etc. And hence i would like to gather info regarding testing facilities available at other manufacturers. so i don't miss any.
Please share images of test track OR proving track with me.
  • Posted 20 Oct 2014 23:45
  • By mrkjmg
  • joined 7 Apr'12 - 14 messages
  • maharashtra, India
Thank you Daniel.
  • Posted 18 Nov 2014 21:21
  • By mrkjmg
I would suggest that any circuit you make is designed with global standards in mind. For CE there are specific tests to be performed, figure of 8 circuit to be run.
Bear in mind arrangements for fuel consumption tests in accordance with global standards.
If you are taking from a manufacturers perspective then build something which not only allows for the endurance testing, but also component, gradient (tilt ramp), fops and rops etc. as well as general testing of every forklift that rolls off the production line as a final seal of approval.
One of the best parts of a test facility is traceability in my opinion. In case of field complaints it is great to be able to pull up digital data showing that a vehicle was correct when it left the factory.
The previous manufacturer I worked for we had two test areas one for the testing of design (tilt table test, rops/fops, fuel consumption, noise, EMC/EMF compliance) and then a separate area for final testing of production forklifts including the figure of 8 circuit, automated load test with tie down for the forklift, dyno (speed) test and service and park brake testing all of which was logged digitally against the chassis via RFID and barcode.
For cabin testing we installed a booth for spraying water all over the truck to test for leaks.
Better to review what your goals are for the test area and what you wish to achieve from your testing, before even thinking about layout etc.
  • Posted 18 Nov 2014 20:19
  • Modified 18 Nov 2014 23:53 by poster
  • By daniel_g
  • joined 13 Jan'06 - 83 messages
  • Flevoland, Netherlands
Kalmar DCG16-900
Crown SX3030TT4250
Prospect CT, United States
Dayton OH/Cincinnati OH, United States
Philadelphia, United States
Davenport, IA, United States
ASSET FINANCE
Nov 2025
Kalmar DCG16-900
Crown SX3030TT4250
ASSET FINANCE
Nov 2025
