No traction in forward or reverse. Please help.
Hi there,
I have a "vintage" Crown 35SCTT which has no traction in forward or reverse. Sometimes there is forward but no reverse traction.
I have changed the two micro switches located by the speed potentiometer. The truck worked well and 3 months later the same fault has returned. When the fault occurs, sometimes the contactors click in but there is no traction. Other times the contactors do not activate at all. The battery is charged regularly.
I have been unable to find an electrical schematic anywhere.
Are there any other micro switches which could cause this problem or is the fault in another area.
Could somebody please help.
  • Posted 18 Jul 2014 22:51
  • By stan_t
  • joined 18 Jul'14 - 1 message
  • Warwickshire, United Kingdom
steer switches either side of steer wheels are notorious for causing drive problems
  • Posted 19 Jul 2014 19:22
  • By crownie
  • Victoria, Australia
Click on my name and send me an email, I can help with a schematic for this truck but your email isn't listed in your profile.
These old girls can be a can of worms, lots of people don't realise there is an EV100 controller in the counterweight, remove the small grey panel with CROWN on it and check the TB1-TB6 screw terminals are secure. I've had these terminals crack on the solder join to the board and cause similar problems, jack BOTH drive wheels up, get an operator to operate the machine and wiggle the TB1-TB6 wires and see if you get traction, or tap the panel with the handle of an insulated screwdriver. Also remove and reseat the PCZ connector and the other two 4 or six wire plugs (name alludes me).
Also, there are two sets of direction contactors, one for left motor and one for right. Do all initial faultfinding with steer wheels in the straight ahead position so both motors operate in the same direction, on full lock the inner wheel turns in the opposite direction to the outer wheel to improve turning and prevent motor stall. If only one set of contactors is operating you need to find out why (operators normally complain of slow traction if so).
Check the handbrake switch if no contactors are operating, you can also press the brake override button as this overrides the handbrake switch to allow for hill-starts and the like. No contactors could also be the start switch by the speed pot. Contactors in but no drive could be the speed pot itself or a connection between it and the EV controller.
  • Posted 19 Jul 2014 14:07
  • By techno_nz
  • Canterbury, New Zealand
Crown RD572513TT6860R
Tusk 350CGH20
Tusk 350CGH20
