code A4
Regarding Cat Order Picker model nor3op. Does anyone know what code A4 is? Unit will not move. As soon as battery is connected I get this code. Thanks. This unit has been acting up for some time now and gives different codes at different times, but now it wont do anything. Also I am new here, thanks again.
  • Posted 11 Jul 2014 04:18
  • Modified 11 Jul 2014 05:18 by poster
  • By DTucker
  • joined 11 Jul'14 - 35 messages
Hi, anyone please assist with A4 error code on Toyota 5FBE15 electric forklift truck.
thank you
Arnie.
  • Posted 23 Aug 2019 22:02
  • By arnie
  • joined 17 Aug'11 - 55 messages
  • western cape, South Africa
arnold@rafforklift.co.za
Hi there, im also new to this website.. I have a code 81 also on a cat nor30p, can you please explain how can a go into the TM and relearn the controls?
Thank you!
  • Posted 13 Jan 2015 07:28
  • By alfonso_c
  • joined 13 Jan'15 - 1 message
  • Baja california, Mexico
code 80 is throttle control out of range
code 81 is lift control out of range
providing all your cables are connected properly and secure in their sockets and no damage to any cables, you need to go into the TM and relearn the controls.
What did you do since our previous posts?
something you may have inadvertently done could be causing this new set of codes. The fact that you are getting simultaneous codes from the control handle for lift and travel is unusual. did you replace the eeprom and/or board in the TM? Disconnect anything while checking the unit and maybe connected back incorrectly or may have damaged some wiring?
  • Posted 8 Aug 2014 21:18
  • Modified 8 Aug 2014 21:19 by poster
The code started again. This time accompanied by code 80 and 81?
  • Posted 8 Aug 2014 01:19
  • By DTucker
Thank You
  • Posted 12 Jul 2014 01:24
  • By DTucker
error code A4 - COP Reset occurred
corrective actions and checks:
- check and clean static straps
- check for shorts to frame
- replace the firmware (eprom)
- install a replacement vehicle manager (the suspect vehicle manager must be returned to mfg for recalibration before it can be used)
i would make sure truck has static strap installed first
then isolate the battery away from the truck and see if code goes away.
if code persists check for shorts to frame in motors and other components.
last would be to replace the firmware or vehicle manager
  • Posted 11 Jul 2014 20:51
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Taylor TT300
USD98,500
Noblelift
Oxford Ct, United States
Esie Cortez Esie Cortez
