TSP6000 raises when aux functions commanded
Got a turret that raises slowly when aux functions like rotate and traverse are requested. Replace PVMR, PVML, swapped all other valves. Do not believe it's an electrical issues since no voltage is detected at cool when aux functions are commanded. Anyone come across an issue like this?
  • Posted 11 Jun 2014 01:04
  • By Rgshock99
  • joined 11 Jun'14 - 8 messages
Rgshock99
Turn out clean out manifold and valves adjusted receive balve a d recalibrate sense and breakout settings thanks for the insight
  • Posted 11 Jun 2014 05:57
  • By Rgshock99
Rgshock99
I've had this issue a couple of times before on another make of forklift.
One was a broken return spring for the main lift valve inside the valve block.
Main lift valve was slow to shut, electrically the lift stopped as commanded but if AUX functions where used within a few seconds the forks would creep up at same time due to slightly open main lift valve.
The other was a sticky valve assembly that controlled hydraulic flow between main lift valve block & the turret valve block.
Again aux functions could cause forks to either raise & sometimes drop at random.
It does sound like you have a sticky or faulty valve somewhere in the hydraulic system, I've never worked on one of these so I've no idea where would be best to look.
  • Posted 11 Jun 2014 04:26
  • By Forkingabout
  • england, United Kingdom
Philadelphia, United States
Dayton OH/Cincinnati OH, United States
Prospect CT, United States
Davenport, IA, United States
Terberg RT403
Tusk 350CGH20
