BT LWE180 BATTERY SHOWN FLAT BUT NOT
THE DISPLAY UNIT IN TILLER HEAD SHOWING 0%.
TESTED BATTERIES ALL OK.TRUCK DRIVES BUT NO HYDRAULICS
CHECKED CURTIS UNIT FAULT WAS HW HARE WARE FAULT NO SIGNAL FROM TILLER HEAD.SWAPPED HEADS OVER WITH A SAME MODEL AND TRUCK WORKS FINE AND PUT FAULTY HEAD ON OTHER TRUCK SHOWS THE FAULT.ORDER NEW CARD AND REPLACED EVERYTHING WAS WORKING OK BUT THIS TRUCK HAS A KEY PAD TO TURN TRUCK ON AND OFF. THE TRUCK JUST POWERED UP KEY PAD DID NOT WORK SO PUT A KEY SWITCH ON TRUCK WORKING OK FOR A MONTH THEN SAME FAULT ACURRED AGAIN.
  • Posted 4 Jun 2014 08:52
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
You must go to parameter settings
You can say key ore key pad thats your problem.
Regards
John.
  • Posted 4 Jun 2014 14:47
  • By johngen
  • NB, Netherlands
Toyota 3FD100
TCM FD80Z7
TCM FD80Z7 1990
Highland, IL, United States
Tacoma, WA, United States
Orlando area, United States
