Yale GE EV100 DC Series SCR Controller Reverse Moving Issue
Hello Everyone,
Yale Truck have some problem While Operating in Reverse Direction.In Forward Direction truck running Normal And in reverse Direction truck starts working and when we apply accelerator for second time truck stops completely and F-R Contactor Opened.
after re key the same issue will continue.
in this truck we modified current sensor between Bat. negative and A2.
Any help will be greatly appreciated.
Thanks and Regards
Binoy
  • Posted 1 Jun 2014 18:27
  • By binoy_b
  • joined 1 Jun'14 - 1 message
  • Kerala, India
hello binoy,
first thing is to check the battery charge and make sure it is fully charged, check cells and make sure no bad cells and fluid level is up to correct level.
second thing is a model and serial number of machine would be helpful
third thing is when error occurs does display show an error code?
fourth thing is now i have to ask, what sort of modification did you do to current sensor? Any alteration to the current sensor will probably cause problems but generally would cause them in both directions, not just reverse. It does mount between the Neg and A2 connection on drive circuit on panel and the yellow and green wires run to terminals 3 and 4 on the "Z" plug on oscillator card. So what modification did you do?
fifth thing is have you checked the contact tips in fwd/rev contactor for burning and wear? check the armature and insulators in the contactor for wear and alignment? If you are not getting good connection on the tips that can cause a drop out and poor running conditions. Generally this is accompanied by some error code on display when fault occurs.
some of the codes you may witness on the display are -03, -15, -23, -24, -42, -43, -47 and so on. Do you see any codes on display when error occurs?
  • Posted 1 Jun 2014 22:29
Hangcha CBD15
China
USD1,600
SMV (Konecranes) 4632CC5
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Toyota launches three new stackers Columbus, IN, United States
