no traction error code 05 in display
Hi I have this problem with a crown fc4000 the machine starts, you have steering and hydraulics but no traction.
The display shows up the code 05 whenever you press the accelerator.
The forward reverse selector works well, the seat switch it's working properly..
I don't have any manual or info about this truck.
  • Posted 8 May 2014 20:52
  • By fernando_m
  • joined 9 Apr'13 - 21 messages
  • Barcelona, Spain
Just had this code. glad i check this thread- found battery door panel switch faulty
  • Posted 15 Sep 2015 22:50
  • By Prentice
I don't have that manual in front of me, but I think Code -05 is an accelerator problem? The accelerator switch is not closing as the truck sees the accelerator potentiometer increase in counts. Both of them are right next to each other under the accelerator pedal. I work for Crown, but it has been a while since I worked on the older FC4000's. You can check your brake switch to see if it is stuck, but it is usually one of them. The brake switch when stuck for more than 3 seconds with the traction command given, will give a code too. Sorry, don't have that book available right now.
  • Posted 2 Jun 2014 01:42
  • By Crown
  • joined 14 Oct'12 - 6 messages
  • Michigan, United States
HAve you checked your batt restraint? Make sure it is installed properly and closing the switch.
  • Posted 20 May 2014 03:24
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
Hi I just went to the truck and the brake seems to be ok if you release the parking brake without seat switch pressed the machine beeps.
  • Posted 15 May 2014 14:48
  • Modified 15 May 2014 16:38 by poster
  • By fernando_m
  • Barcelona, Spain
Thanks for the answer!! I'll check it later and I let you know.
  • Posted 15 May 2014 10:05
  • By fernando_m
  • Barcelona, Spain
05 is a batt restraint/brake code. Could be batt restraint switch not closed (restraint not properly installed). Might be bad switch too???
It could also be parking brake switch.
  • Posted 9 May 2014 01:12
  • Modified 9 May 2014 01:17 by poster
  • By chevotaman
Sue Tomic Sue Tomic
SMV (Konecranes) 4538CCX4
Aichi SR10C1SM
Aichi SR10C1SM
Sue Tomic Sue Tomic
