code 35
code 35 sometime
  • Posted 30 Apr 2014 08:45
  • By raj_h
  • joined 24 Apr'14 - 9 messages
35 Pump Motor, Armature Over-current
Possible Causes:
Faulty CS3 current sensor, faulty wiring, faulty logic card.
Checks:
Disconnect battery plug. Check regeneration and line contactor tips for melting (shorting). Make sure each contactor
tip moves freely.
could be a faulty line contactor
could be a faulty current sensor
could be a faulty T1P IGBT
could be faulty wiring to logic card
or a faulty logic card
also to rule out any battery issue check the battery and make sure it is charged and has no bad cells.
  • Posted 30 Apr 2014 11:08
Taylor T650L
Terberg RT223
Esie Cortez Esie Cortez
Taylor T650L
Terberg RT223
