combilift c4000 steering fault
when wheels are all in one dierection going forward and reverse.
turn key on the dierection lever is in neutral turn key on but not start dierection light comes on point for side way drive you start up and the main steer wheel will turn but not front ones but lever is still in neutral.but it is intermittent.but the customer has said they have had the steering wheel keep on going around and around.
  • Posted 28 Apr 2014 04:33
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
have a little info if any use need email
  • Posted 6 May 2014 05:43
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
ok thanks for that info
but as i suggested
check your sensors and steering stops first
last time i dealt with this issue on the rear steer wheel one of the sensors was not adjusted right and the stop was loose
  • Posted 29 Apr 2014 09:09
model c4000
serial 7487
  • Posted 29 Apr 2014 04:07
  • By greasespoon
model c4000
serial 7487
  • By greasespoon
model c4000
serial 7487
  • By greasespoon
like micky suggests, need full model and serial number of said unit to give you accurate info.
But in general most combi units utilize steering limit sensors that do get out of adjustment and will cause issues like this. One other thing also is the wheels have stops on them to keep them from turning past their designated allowed turning points.
So if the wheel is turning around and around as you put it then i'd make sure the steering stop isn't broken or missing.
And of course check the steering sensors.
There should be 2 on the rear steer wheel and 2 or 3 on the front left wheel depending on the type of steering system is on the truck.
Regular trucks with just fwd/rev , side to side steering would only have 2 sensors per wheel. The trucks that have crab steering would have a 3rd sensor mounted mid travel of the steer rotation.
  • Posted 28 Apr 2014 20:30
Hi Mate,
Can you advise rest of model number also serial number with YOM.
I also need your email address.
Mine is in my profile.
Micky.
  • Posted 28 Apr 2014 18:54
  • By micky_h
  • joined 26 May'11 - 205 messages
  • South Elmsall, United Kingdom
Hi Mate,
Micky
  • Posted 28 Apr 2014 18:53
  • By micky_h
Hi Mate,
Micky
  • By micky_h
Highland, IL, United States
Tacoma, WA, United States
Orlando area, United States
