steering faults
when wheels are all in one dierection going forward and reverse.
turn key on the dierection lever is in neutral turn key on but not start dierection light comes on point for side way drive you start up and the main steer wheel will turn but not front ones but lever is still in neutral.but it is intermittent.but the customer has said they have had the steering wheel keep on going around and around.
  • Posted 28 Apr 2014 04:32
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
Hi,
The proxy sensors unfortunately do get impacted and as they are needed to control the movement to the alternative directional change, a loose or impacted one should always be checked for. When a truck ships new a spare one is provided in the cabin.
If you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support.
Combilift has Technical support technicians across the world including in NC at the North America Headquarters, that can help.
You can also request access to our knowledgebase where you will find more information available. Hope you get sorted.
  • Posted 20 Mar 2024 00:57
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Check proximity switches on steering. There should be two switches at each wheel. Make sure the gap between switches and pickup tab isn't more than.25 inches. The factory doesn't do a very good job setting them up.
  • Posted 19 Mar 2024 23:51
  • By Pat_Simkins
  • joined 3 Apr'20 - 10 messages
  • New Jersey, United States
Pat Simkins
Generally there are issues with the sensors on the rear wheel. Have lots of problems with worn turntable bearings and the steering ram trunions not allowing the wheel to come around enough.
  • Posted 1 Aug 2019 00:03
  • By CHRISCARRYLIFT
  • joined 18 Mar'08 - 24 messages
  • 0000, United Kingdom
Ice 28INCH-AUTO-SCRUBBER
USD8,350
UN Forklift FGL25T
USD8,350
UN Forklift FGL25T
Deborah Baker Deborah Baker
USD8,350
UN Forklift FGL25T
Muncie, IN, United States
