kalmar c30-ax no start
have a start prob. has k21 Nissan motor, had code for camshaft sensor replaced, ran good for about ten min. tried restart, won't. not throwing any codes, did **** timeing, with hand set. started running. let sit four couple hours wouldn't restart. back to square one. any help would appreciate ps. has tier 2 setup, 2007
  • Posted 2 Apr 2014 00:18
  • Modified 2 Apr 2014 00:22 by poster
  • By confusedtom
  • joined 2 Apr'14 - 11 messages
I had a similar issue and it turned out to be the ignition coils. Test each one and see if you have a spark
  • Posted 4 Apr 2014 18:13
  • By sako_k
  • joined 12 Mar'14 - 17 messages
Sako1sk at yahoo dot com
set timing back to factory default
change spark plugs
see if that helps
  • Posted 3 Apr 2014 01:27
Unicarriers FHGE35T5S
