DATSUN CPG103-1
I have red oil leaking from the front axle. I removed the axle and there is a seal Inside the axle tube and he's shot.. You have to remove the cover of the differential to change it from the inside. Can we punch a hole in that oil seal, and the Wheel bearing will be lubricate from the oil of the differential. Or we have to remove the fork system and change it from the inside.
Thanks!!!
John
  • Posted 1 Apr 2014 10:16
  • Modified 1 Apr 2014 10:18 by poster
  • By ORFORD2004
  • joined 1 Apr'14 - 8 messages
  • Quebec, Canada
Showing items 1 - 15 of 15 results.
Are there slots in the backing plates near the bottom?
  • Posted 25 Apr 2014 10:19
  • By bbforks
Shoes are brand new and there is only 2 adjusters.
  • Posted 25 Apr 2014 07:38
  • By ORFORD2004
  • Quebec, Canada
Those are the adjusters. There should be 4, one for each shoe. They are an eccentric cam that rotates and pushes the shoe outward towards the drum. The jumping must be when the highest spot on the cam goes by where it pushes the shoe. You have to turn all 4 adjusters so they push the shoes out close to the drum. If the adjusters rotate all the way around the shoes may be worn out. I would pull the drums and take a look in there.
  • Posted 24 Apr 2014 21:18
Another question. How do you adjust the brake? On the top Inside, there is a 17mm nut that if you turn you feel resistance and it feel like if it jump something and free again. The pedal goes right to the floor. No air in the system.
Thanks!!
  • Posted 24 Apr 2014 12:31
  • By ORFORD2004
  • Quebec, Canada
Look like the counterweight is not that heavy because the job is done and nothing happen.
At the end of the axle, i have 2 holes 10X1.25. Is it for grease nipples? And where do i get them?
Thanks!!!
John
  • Posted 6 Apr 2014 11:43
  • By ORFORD2004
  • Quebec, Canada
Yes, the mast is going to weigh near 1,000 Lb.
Something else to consider here in jacking and blocking a truck for repairs where the mast system is being removed is that you must either remove the counterweight from the truck, or block up underneath the counterweight so that the counterweight mass does not become dominant when the mast mass is separated from the truck.
If the counterweight is left on and there is no blocking under it, the truck might tip backward when the mast is separated. This is something that must be addressed properly before unbolting the mast.
  • Posted 4 Apr 2014 01:26
  • By L1ftmech
  • Tennessee, United States
What oil did i put Inside the diff. The old one was red?
  • Posted 4 Apr 2014 00:03
  • Modified 6 Apr 2014 11:45 by poster
  • By ORFORD2004
  • Quebec, Canada
I would disconnect the hyd's first, then the 2 clamps. I've never weighed an upright but I'd guess in the 1,000 lb range.
  • Posted 2 Apr 2014 21:48
  • By bbforks
You remove the seal from the inside. Now i have to remove the fork system. I disconnect the tilt cylinders and it look like there is 2 clamps bolt around the differential axle. You disconnect the hydraulic system and then the 2 clamps? also what is the weight of the fork system?
I send you pictures.
Thanks!!!
John
  • Posted 2 Apr 2014 11:09
  • By ORFORD2004
  • Quebec, Canada
Received your pictures- it re-booted my brain on this truck- the 3 foot stick I remembered was the parking brake lever- not the f/r lever.
From your picture I believe the seal could be replaced with a long slide hammer for removal (you'd have to make a hook assy to grab the seal) & a piece of pipe to install from the end of the axle tube
The reason I asked on the model is because your lift has the weakest union between a crankshaft & torque converter I've ever seen. You have to disassemble the torque converter (it bolts together) in chassis & remove some snap rings to get the converter out to get to the union- which is a coupler about 2" thick held in place with 6- 5/16" bolts (or their metric equivalent). All power from the engine goes thru this coupler. Make sure you always come to a complete stop when changing direction, make sure you're always at idle when you either 1)- put trans in gear or 2)- release the inching pedal.
Once this coupler gets some play (bolts loosen/break), you'll start leaving a trail of ATF on the floor. It really leaks like crazy even if the coupler isn't really that loose. Very bad design & a real challenge to repair.
  • Posted 2 Apr 2014 00:56
  • Modified 2 Apr 2014 00:57 by poster
  • By bbforks
Well- to be honest I'm at a loss- sorry for the wrong directions. I've never seen an axle seal in the position you describe.
If you can- send me a picture of the lift to my email- I thought I knew this model- the earth could be off it's axis & I made a mistake LOL
  • Posted 2 Apr 2014 00:18
  • By bbforks
lever by steering column
  • Posted 1 Apr 2014 21:47
  • By ORFORD2004
  • Quebec, Canada
Does this lift have the f/r lever coming up out of the floorboard (about a 3 foot stick) or is the directional lever by the steering column as on a car?
  • Posted 1 Apr 2014 12:25
  • By bbforks
No the seal is near the differential. So about 6 inche from the end of the tube and you remove it from Inside the differential. Or maybe i'm wrong.
  • Posted 1 Apr 2014 11:50
  • By ORFORD2004
  • Quebec, Canada
If I follow you there's a seal just inside the axle tube (almost flush with the outer end of the tube). If I'm correct, this seal can be replaced without the differential being disassembled. If you put a pry bar across the opening of the axle tube with one end of the pry bar just inside the seal (catching the inside lip of the seal) it can be pried out. Replacing it is just as easy, using a small hammer to push the seal into position.
  • Posted 1 Apr 2014 11:06
  • By bbforks
Esie Cortez Esie Cortez
Hyster
