275 error code
i put the power lead in the wrong way round, now coming up with 275 valves controller fault, can anyone help me?????
  • Posted 22 Mar 2014 01:15
  • By aidan
  • joined 22 Mar'14 - 2 messages
  • essex, United Kingdom
Internal failure of the valve driver module.
No operation of the electro-hydraulic functions.
Probable Causes and Test Procedures
- Ensure all fuses are properly seated and tight in the fuse holders.
- Ensure all wiring connections are tight and secure at the fuse panel, key switch, and the battery disconnect switch.
- Check that the battery disconnect switch, the key switch, and the main contactor contacts are in the correct position and properly making contact.
- Recycle the key switch from the OFF to the ON position.
- Check all pins at the valve controller connector are tight and secure.
- Replace the valve driver module.
  • Posted 24 Mar 2014 19:58
model- J1.60xmt (545)
serial- J160ao2824c
thanks
  • Posted 24 Mar 2014 18:44
  • By aidan
need more info
full model number?
serial number?
  • Posted 22 Mar 2014 13:33
UN Forklift FBT18NQZ1
UN Forklift FGL18T
edition #1248 - 18 September 2025
In May 2023, a Belgian Malinois named Wilson played a key role in the rescue of four children lost in the Amazon jungle. The young children were missing for 40 days after a plane crash that killed their mother and other adults. Wilson tracked the children's footprints, leading the military to their location.
