CAT WR6000 /Jungheinrich electric pallet jack- Handle limit switch..just one ?
CAT 6K electric pallet jack (really a Jungheinrich) has the strangest problem... turn it on, pull down the handle to use position, turn motion bars...and if it's 65 degrees or colder in the room...nothing happens.
If it's 66 degrees or warmer, it works fine.
When it doesn't work, the "rabbit" button will still work to get some motion... allbeit slow. In other words the jack acts exactly like it would if the handle limit switch was defective.
But it doesn't seem to be...I consistently get.4 ohms when the switch is closed.... and the probe wires by themself have.3 ohms. If it matters, that's checkin it when the jack isn't working.
So, is there a second limit switch hidden away on the right side that might be defective ? Or is continuity so critical that even.1 ohm could make a difference ? Or perhaps the problem is in whatever that limit switch allows "on" ?
  • Posted 18 Mar 2014 13:53
  • By Milacron
  • joined 25 Nov'06 - 80 messages
Yep, fixed it. As it turns out, there are indeed two limit switches for the handle pivot. The switch I mentioned in my post was the left side switch but the problem was the right side switch.
The switch on the right side is hard to find but it's in there...I had to remove the bracket that holds the handle electrical harness plug to get to it. Switch was ok internally but the metal "spring" on the outside was no longer pushing the limit switch button in enough when the handle cam was in position to do so.
The cure was to take needle nose pliers and simply bend that spring back to it's original position so that the cam would properly engage the switch again. Works great now.
Now that I know what the problem was I feel a bit silly having mentioned the temperature aspects but apparently it was so close to engaging the switch that the termperature effected the metal spring by a few thousandiths of an inch enough to make the difference in engagement or not. But by the time I figured out the problem even the warmer temps no longer helped..it was to the point of never working no matter what the temperature. Please let us know if that was your problem as well once you work on it.
  • Posted 6 May 2014 02:23
  • Modified 6 May 2014 02:26 by poster
  • By Milacron
Hi were you able to fix this?
I have the same problem
  • Posted 6 May 2014 01:27
  • By jin_c
  • joined 6 May'14 - 1 message
Terberg YT223
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Bobcat appoints new UK dealer Liverpool, United Kingdom
