DU 129474
Not sure if this is right truck. We have had the du come back for broken axles , snapped between the ring gear and preload nut. we have also had recent problems with all or some of the half inch bolts snapping but leaving the safety wire like new unbroke. Has anyone seen this problem. If so How are they doing this ? how do you stop it. Have been doing this for 15 years only saw one broke axle , never seen broken bolts.
  • Posted 11 Mar 2014 09:15
  • By phillip_d
  • joined 2 May'12 - 9 messages
  • Missouri, United States
I work for Crown and we always replace the drive unit with a new or remanufactured one instead of rebuilding them. My boss don't allow us to rebuild them. Not cost effective, even for our full maintenance accounts where we pay the bill. It also comes with a 1 year warranty. Most of the time when I see these fail, it is because the operators are bulldozing pallets. This always tears up these drive units. They try to push 5 or more pallets causing hard stress on the motor and the drive unit. Usually the drive unit goes first.
  • Posted 2 Jun 2014 01:16
  • By Crown
  • joined 14 Oct'12 - 6 messages
  • Michigan, United States
I always use a matched set..I run a ink pattern to determine the correct setting for the ring& pinion. My Boss talked to crown. They have had a problem with breaking bolts.
  • Posted 24 May 2014 07:37
  • By phillip_d
Improper Shimming on the ring gear, or not installing a matched Ring and Pinion can lead to the Bolts breaking. We ran through this while back. Started installing mathced sets, and the problem went away
  • Posted 24 May 2014 02:22
  • By levi_m
  • joined 24 May'14 - 4 messages
  • Indiana, United States
