Yale ERP18 year 2001
Hi, I have forklift of the model above and it have error 16 HIGH VOLTAGE at display, it happens after change and old battery to a new one on the machine. These parameters can be changed with a console? The controllers of the machine are General Electrics and I have a console but the plug not match, someone knows if exists an adapter?
Thanks.
  • Posted 28 Feb 2014 02:56
  • By filipe_f
  • joined 13 Jan'14 - 26 messages
  • ----, Portugal
I have the EV100 and the correct cable ( http://galleryplus.ebayimg.com/ws/web/141123754175_1_0_1/1000x1000.jpg )but I link all in the controller and turn on the machine and it not works... and if it works I don't know how use it, don't have a manual or codes list. Are there some way to fix error 16 without use the handset?
and yes in the back of display have a port to connect to it but I don't have the cable and the software...
  • Posted 3 Mar 2014 02:55
  • By filipe_f
  • ----, Portugal
Hi Filipe I think I have misunderstood your post, yes Swoop has given you more accurate information, you can get a lead for the EV 100 hand set but I can't see the prt/no in the workshop manual. It may be in a parts manual but I don't have that info, you can connect laptop with soft ware as swoop says under dash console triangular connector but you need correct leads.
  • Posted 28 Feb 2014 19:55
  • By NER045
you can use the EV100 handset to change the values in this controller as long as you have the correct cord that connects directly to the controller box plug.
Also can use the pc laptop and the ge sentry program as long as you have the correct cable. Or you can get the GE cable for laptop and connect directly to the controller.
On the Yale trucks i'm pretty sure there is a serial db9 port under the display unit but you need the yale software to access the system from that port.
  • Posted 28 Feb 2014 10:09
  • Modified 28 Feb 2014 10:18 by poster
Yes you can can get a lead specifically to fit the G.E.C. SEMs unit and hand held diagnostic unit. I will have a look and see if I can find a Yale part no.
  • Posted 28 Feb 2014 05:20
  • By NER045
Toyota launches three new stackers Columbus, IN, United States
Hyster
