shuts off
I have a cat dp30 diesel lift. The lift will run, idle, and drive fine for a few minutes then will shut off like you turned off switch. After a few times I have to crack the injectors to get it started back. Any suggestions?
  • Posted 10 Jan 2014 02:20
  • By cgarner1979
  • joined 13 Dec'13 - 24 messages
  • Alabama, United States
you may also want to remove the banjo bolts on the fuel lines at the injection pump, they have screens in them that can get clogged over time and can cause this problem too.
  • Posted 10 Jan 2014 21:25
  • Modified 10 Jan 2014 21:25 by poster
We had a similar problem. found the fuel primer above the Fuel filter losing pressure.
Check fuel shut off power supply at bottom of injector pump
Check Manual fuel primer pump
Also rare but we have had contamination( Dirt, Plastic, sludge) in bottom of fuel tank to block off suction line
good luck
  • Posted 10 Jan 2014 02:46
  • By Prentice
Mitsubishi FD200
Terberg RT223
Esie Cortez Esie Cortez
