HYSTER h280 (big truck) no side shift
Had customer pull the hyd side shift mast cable off (12 wire terminal).( truck was working well before driver damage cable).
Replaced cable from carriage to hydraulic module. but no side shift
has lift and tilt. when operating side shift joystick I do get hyd pressure to side shift cylinder from hyd value.
but not to side shift solenoids at carriage
truck has two hyd modules
any help please !!!! thanks
  • Posted 8 Jan 2014 13:54
  • By studog
  • joined 8 Oct'10 - 12 messages
AAPPE PROBLEM IS I DON'T GET ANY POSITIVE 24 VOLT OUT OF MODULE TO CARRIAGE ASSY
TRUCK ONLY HAS SIDE SHIFT ALL OTHER WIRES NOT USED
THANKS FOR THE INFO
  • Posted 9 Jan 2014 06:08
  • By studog
the are not the same.it shoud be possble to change the input and output on another line there are 1 line not used
  • Posted 9 Jan 2014 03:52
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
AAPEE THANKS
TOP PGM MODULE WORKS , I GET 1. TO 5. VOLTS FROM HYD
LIFT, TILT , S/S POT
BOTTOM MODULE , THINK IS DAMAGED HAS LED LIGHTS AND LIGHTS UP
BUT NO 24 VOLTS TO S/S CARRIAGE SOLENIODS
I'M NOT SURE HOW SYSTEM WORKS
IS THERE A WAY TO TEST BOTTOM MODULE.
ARE THE TWO MODULES THE SAME , THEY LOOK A LIKE
THANKS
STU
  • Posted 9 Jan 2014 01:01
  • By studog
I/o card 1 outputline no signal ther ar 2 cards the bottum card this is plug and play
  • Posted 8 Jan 2014 17:02
  • By AAPEE
  • Brussels, Belgium
Toyota launches three new stackers Columbus, IN, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Manitou MH25-4
Hoist Liftruck F180-36BOX-CAR
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Board member, UKMHA
