Eagle Picher RT60 Forklift
After replacing a bad alternator, had an issue with the new alternator not charging. Ran a direct ignition wire to alternator and alternator does charge but will not shut off, has a back feed from alternator. Is there a wiring diagram or relay that we need to change as well? it is a 2002 RT60 - ser # 2T602WD2RT01166. Thanks in advance for your help.
  • Posted 1 Jan 2014 02:57
  • By Scobbi
  • joined 1 Jan'14 - 1 message
  • Arizona, United States
If you need to run a wire , run it from the accessory side of the key switch , not ignition side.
  • Posted 10 Jan 2014 10:02
  • By jim_k
  • joined 28 Aug'08 - 21 messages
Sounds like there's a blown charging indicator light, do any lights on the dash come on when the ignition key is turned to run but not start?
  • Posted 2 Jan 2014 03:02
  • By bbforks
you could try a diode in the wire...
  • Posted 2 Jan 2014 00:03
Hawker Powersource, Inc.
Toyota launches three new stackers Columbus, IN, United States
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
