Electrical Forklift: Not Move
Greetings all
I am salute you from Chile.
My brother owns a Forklift, this is the model.
YALE ERCO50ZG 48 VOLTS SERIAL V13660X
He had the EV100 hand set and show error 67 and 93
The traction motor it is ok, and conected. Power supply lines seems correct too.
Thank you for you are assistance.
Best regards and wish you happy Christmas
Cristian
  • Posted 12 Dec 2013 22:57
  • By gruashorquilla
  • joined 26 Oct'13 - 7 messages
  • Valparaiso, Chile
status code 67: Short Circuit sensed on power output to pump motor.
Possible Causes:
- Short circuit in motor or heavy power wires going to motor.
- If status code is displayed when power wires are disconnected, short circuit is internal.
- Replace motor controller
status code 93: Power steering motor brushes are worn
Possible Causes:
- pump motor brushes are worn too short
- motor brush wear sensor wires to motor controller may have a short to battery positive.
  • Posted 13 Dec 2013 23:42
  • joined 23 Mar'12 - 3,693 messages
Thank you Titus for you are quick response. I will resend this to my brother. Greetings from Chile.
  • Posted 13 Dec 2013 05:05
  • By gruashorquilla
  • Valparaiso, Chile
Hi I don't think code 67 is correct you may have to check it again.
It may be 76 if so its been to some fault occurring during regen braking causing C1 to have to high a voltage. This results in the forward and reverse contacts pulling in and falling out and then will only close when the key switch is open and closed.
93 possibly due to hyd motor to hot, temp sensor has closed to battery negative.
I hope this info is helpfully. Regards Titus
  • Posted 13 Dec 2013 03:04
  • By Titus
  • joined 6 Jul'10 - 185 messages
Sue Tomic Sue Tomic
Elwell-Parker ESI500-36
Mitsubishi FGE35AT
Sue Tomic Sue Tomic
Mitsubishi FGE35AT
Combilift Ltd
