yale hyd problem
ecr050ghn48te088 a908n08804f hydraulics chatter codes 67 53 and 42 pump control temp too high any help much appreciated tried diff logistics motor checked ok batt ok
  • Posted 6 Dec 2013 02:09
  • By lonster
  • joined 23 Jul'10 - 38 messages
if you can, you should also check the encoder bearing. usually chattering on AC motor is more often related to the encoder bearing than anything else.
  • Posted 10 Dec 2013 02:04
thanks Edward will pass that on
  • Posted 10 Dec 2013 01:12
  • By lonster
On trucks with A/C power control of the hydraulics, it's important to set both hydraulic pressures and amperage current limit using an a/c amp meter AND a pressure gauge. (Does this truck have a corrected [to show the clamp] data/capacity plate?, as required.)
Although I usually think that a 3 phase A/C motor in a forklift that has "chattering", especially at start-up of the motor, is more often than not the "encoder bearing", this may be as simple as adjusting the switch/sensor to match the pump ramp up with the valve's spool position.
  • Posted 8 Dec 2013 01:02
  • Modified 9 Dec 2013 00:17 by poster
thanks swoop tech now tells me its only when you first use it gets better as you use it and yes it has a bale clamp seems to be telling us heat problems when its not up to temp strange will let you know what we find
  • Posted 7 Dec 2013 09:52
  • By lonster
well the most common problems for code 42 are listed as excessive usage or stalling the pump/motor.
cooling fans not working or maybe blockage of airflow
and also insufficent amount of thermal grease between controller and heatsink panel.
you may also want to consider that if you are using any type of attachment like a rotator or bale clamp or something like this.
attachments are notorious for heating up hydraulic systems because of the heavy load they create on the system.
all of these codes could be caused by that one single problem due to heat.
just some thoughts...
  • Posted 6 Dec 2013 06:36
Toyota launches three new stackers Columbus, IN, United States
Bobcat appoints new UK dealer Liverpool, United Kingdom
Orlando area, United States
Highland, IL, United States
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
Enforcer FLBAXT25
Terberg YT223
