I have a electric AC nissan, and this one have a 2 days new 36v battery with complete charge and change the maine power fuse, my trouble is in the display shown "recharge battery".
and in the confuguration software of the forklift, want to change from 48 to 36 v, and I cant, the software change the parameter but not record, all parameters saved it, except the battery volts.
any one knows about this forklift???
I very appreciate your comment, i find the trouble with the change of the parameter,
was a broken wire, change it and, i could change from 48 to 36v.
now, in this one (forklift), i find another trouble, the stop switch wires burn it, and a lot of work to do.
I wished i could help you but as it is copyrighted material and i live in the USA, i cannot share this info. The lights are pretty straight foward. You will have to change from 48v to 36 volt if using 36 volt battery.
Thanks for your info.
Now I try to fix the combination lights, but I have not the diagram for this, any one can help me and share the wiring diagram and schematics for the entire electrical system or at lease the lights front and rear please!!!
Nissan model G1N1L20V CHASSIS # G1N1-720489
Once you select 36v are you entering it or selectingit with #5 key? If you cannot change any of the parameters then you have a dash lock combination you will have to enter to change parameters. Once parameters are changed, you can relock the dash.
hi raul the forklift that you have has never been 36v unit it is only 48v I take it that it is a 1N1 unit ?? you cannot change it to 36v
