Komatsu FG15T-15
Hi all I dont know if there is anyone old enough to remember the old Komatsu FG15T-15 sn 342281 with manual transmission ,stick shift. I have one with a worn clutch Does the spigot shaft ,primary shaft withdraw somehow or is it an engine out job any input would be greatly appreciated
  • Posted 1 Nov 2013 18:43
  • By nick_c
  • joined 17 Jun'11 - 116 messages
  • south glos, United Kingdom
Hey Nick, Thanks so much for the info.... this is a huge help. My forklift seemed to be working fine, making strange throw out bearing noises... but clutch was working and engaging.... then,,,, all of a sudden, I press in the clutch and no disengagement.... cant put it in gear.... Im assuming that throw our bearing took a dump... or pressure plate failure, broken springs, and or fingers....???? Ill pull the clutch pak out and rebuild the pressure plate and clutch,,, find another throw out bearing and I should be good. thanks again,, J
  • Posted 23 Apr 2014 16:07
  • By ratfink
  • joined 18 Apr'14 - 3 messages
  • Washington, United States
If you take the top cover off you will see a circlip around the outer shaft , with a screw between the eyes to stop it rotating. Remove the circlip and screw, then with a screw driver slide the inner shaft through to clear the plate.Splines can be a bit tight.
  • Posted 22 Apr 2014 23:45
  • By nick_c
how do you move the shaft?
  • Posted 18 Apr 2014 18:40
  • By ratfink
Thanks Mark. just hope I can get the parts now!!!
  • Posted 1 Nov 2013 20:59
  • By nick_c
Hey Nick, I must be getting old thank you for reminding me;)
You can move the primary shaft, and you don't have to remove the motor or transmission for changing the clutch.
Kind regards
marcb
  • Posted 1 Nov 2013 19:31
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Highland, IL, United States
Tacoma, WA, United States
Orlando area, United States
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
