TCM FTB16-7 Error code 219 & 419
Hi there,
Can anyone assist me with error codes on the FTB16-7? the machine got bumped and now error 219 and 419 come up on the machine. there is no hydraulics or traction. the local TCM agents cannot help me with error codes for some reason as they say the machine is one-off they brought in.
  • Posted 1 Nov 2013 01:10
  • By Tarpon
  • joined 9 Jun'09 - 9 messages
  • Western Cape, South Africa
Showing items 1 - 17 of 17 results.
Hi,
We have the same issue with our truck, please could you send PDF, if you have available please?
[email address removed]
Regards,
Denise
  • Posted 17 Jul 2024 23:31
  • By darryl_m
  • joined 28 Feb'17 - 10 messages
  • Mid Glam, United Kingdom
D Moseley
Hi has anyone got to the bottom of this fault 219 & 419? I have the same issue with a truck in our workshop or anyone got info on pdf they can share please.. Tia..
  • Posted 10 Dec 2023 04:25
  • By Paul_Healy
  • joined 10 Dec'23 - 1 message
  • Ireland
Could you help me out with the test procedure also?
  • Posted 12 May 2020 02:07
  • By jAMES_Bieber
  • joined 12 May'20 - 5 messages
James P Bieber
That would help. Thanks
  • Posted 10 Mar 2016 21:42
  • By ifsmike
  • joined 7 Jul'11 - 50 messages
when all else fails ,stand back and observe
Hi Mike, I should have the PDF file on how to check the FETS. will fwd it to you.
Craig
  • Posted 10 Mar 2016 18:04
  • By Tarpon
Mike Perry Ifs Gmail
  • Posted 9 Mar 2016 04:17
  • By ifsmike
E-mail please...
  • Posted 9 Mar 2016 03:23
  • By paulo_fernandes
  • joined 1 Feb'13 - 48 messages
  • Montijo, Portugal
paulo.j.fernandes@hotmail.com
Thanks
  • Posted 9 Mar 2016 00:24
  • By ifsmike
I am having the same issue. Could I get troublescorting for these codes to change out the correct parts. Thanks
  • Posted 9 Mar 2016 00:23
  • By ifsmike
Thanks for the info Gentleman, will start doing tests on the modules to see if blown.
  • Posted 11 Nov 2013 23:33
  • By Tarpon
hello, see your email.
Best regards, Laci
  • Posted 8 Nov 2013 03:04
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
craig at saforklift dot co dot za
  • Posted 7 Nov 2013 22:20
  • By Tarpon
your mail?
  • Posted 7 Nov 2013 21:37
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
Can you test the modules to see if faulty. Are there any other Machines that use the same modules if need to be replaced?
I cannot see any parts that are blown on the machine.
  • Posted 6 Nov 2013 00:25
  • By Tarpon
the catalog of spare parts I do not have.
What about the modules - they should be changed to the new not repairable, check the driver.
A lot of ideas have options, I do not understand why do IGBT a very high price used developers (only 48v), with this task easily do mosfet assembly, only to watch the heat sink.
  • Posted 4 Nov 2013 01:45
  • By alexandr_k
  • Ukraine, Ukraine
thanks Alexandr. Can the modules be repaired, or must they be replaced? Any idea where I can find a Repair or Parts manual for this model TCM.
  • Posted 1 Nov 2013 16:09
  • By Tarpon
219 Drive power module upper-side FET shorted
419 Upper FET of pump motor power module shorted
all deal with the IGBT is very necessary to work cautiously.
No right to make mistakes.
  • Posted 1 Nov 2013 05:01
  • By alexandr_k
  • Ukraine, Ukraine
UN Forklift FD50T-NJB3
SMV (Konecranes) 4632CC5
Muncie, IN, United States
