Stalling when turning wheels
So the title pretty much says it all. The forklift is stalling when we are turning wheels.
Any one has got some ideas on what could be wrong?
Any help would be appreciated
  • Posted 30 Oct 2013 19:03
  • By kristaps_p
  • joined 30 Oct'13 - 3 messages
  • Garkalnes pagasts, Latvia
Some Hysters use a vacuum dashpot on the carb's throttle lever to speed up the engine when it's about to stall. As the engine stalls, the dashpot loses vacuum and extends its actuator which hits a lever on the throttle and "catches" the engine before it shuts off from the RMPs dropping to low.
If so equipped, make sure it's adjusted properly or is working at all.
  • Posted 6 Nov 2013 11:51
  • By justinm
Thank you Sir for your answers.
We were thinking about orbitrol valve but we didnt wanned to do that because its very expensive.
Today we visited another customer and he had the same problem with his hyster even thou it had only 900h.
  • Posted 1 Nov 2013 00:15
  • By kristaps_p
you'll want to check all your pressures first
Hydraulic Pump
Type Gear
Priority Flow 10 liter/min (2.64 gal/min)
Relief Pressures
Steering (at Pump) 10.6 to 11.7 MPa (1540 to 1700 psi)
Primary (at Control Valve) 21.37 plus or minus 0.5 MPa (3100 plus or minus 75 psi)
Secondary (at Control Valve) 15.5 plus or minus 0.5 MPa (2250 plus or minus 75 psi)
if all those are at correct settings then you might need to check for something binding at the wheels or just by some slight chance you have a flaky priority valve or relief valve or even possibly a flaky orbitrol valve.
  • Posted 31 Oct 2013 23:57
  • Modified 1 Nov 2013 00:00 by poster
engine stalls when turning wheels when forklift is not moving.
  • Posted 31 Oct 2013 18:26
  • By kristaps_p
Does the engine stall only when turning the steering or only when the steering dead heads?
  • Posted 31 Oct 2013 00:49
  • By bbforks
Esie Cortez Esie Cortez
Terberg YT223
SMV (Konecranes) 33-1200C
Terberg YT223
