YALE MR16 Reach Truck needs Blue Light fitting C849
I need to wire in a blue light to work when travelling in reverse. The truck has got a reverse sounder that operate when the pedal is pressed. The direction switch is just a momentary switch. Has anyone any ideas or can anyone recommend were to wire in the blue light.
  • Posted 29 Oct 2013 21:41
  • By Leon_W
  • Tyne & Wear, United Kingdom
Leon W,
Is this light you want to fit a flash beacon, if so Then Yale specifye a dedicated connection.
There are some dedicated aux fuses located forward of the deadman line contractor check to see if one of these becomes live when accelerator pedal pressed, I certainly would not connect up any other way on this truck as I'm sure Yale specify a dedicate connection infact I would not connect any aux unless you know the correct connections to make.
Regards Titus
  • Posted 30 Oct 2013 03:34
  • Modified 30 Oct 2013 20:38 by poster
  • By Titus
  • joined 6 Jul'10 - 185 messages
Bobcat appoints new UK dealer Liverpool, United Kingdom
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
