main lift ram rebuild help
I have a c500 ys200 converted to a squeeze front end used for moving blocks of hay, the lift ram is leaking out of the bottom, I already bought a seal kit from my local gray lift. My problem is to get the ram out i have to lift the forks all the way up till i clear the top of the ram, then i have to somehow hold the inside track and the forks up while i remove top c clip, lower the ram, then remove it from underneath. How do I keep the forks and inside track up in the air, has any body done this before? Thanks for any input or ideas
  • Posted 12 Sep 2007 11:47
  • By adam_f
  • joined 12 Sep'07 - 3 messages
You know you can disconnect the primary lift chains and lift in inner rail off the carriage, right?
  • Posted 4 Apr 2008 09:31
  • By larry_m
  • joined 4 Apr'08 - 12 messages
Yeah thats what i was thinking of just using chain to hold it up, Heres the serial numbers:
CLARKLIFT
C500-YS200D
Y1625-30-3665 277
7612122 BRODI SIDESHIFT
WSS16650 24 210 24
  • Posted 13 Sep 2007 01:23
  • By adam_f
Yeah i'll get them for you tomorrow, thanks for the reply
  • Posted 12 Sep 2007 13:40
  • By adam_f
Hi,adam f. Do you have a serial#? Also,do you have the mast #?
  • Posted 12 Sep 2007 12:29
  • By Truck_Tech
  • United States
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
edition #1250 - 2 October 2025
Mitsubishi FGE35AT
Taylor T650L
VETTER Industrie GmbH
