yale gp080vx code 653-6
Hi everyone! I have a gp080vx It has a gasoline only vortec 4.3 v6. The unit will start and run for two seconds then shuts off. The original problem is that the unit had sat so long with old gas. drained the gas installed new gas and still the same problem.I went into the display and cleared the codes then it ran about 30-45 seconds until codes popped up and then shuts the truck off.If anyone has a manual i would greatly appreciate it. email [url/email removed] the code popping up is a 653-6 and before i erased the code history i believe it was a 654-6,652-6,656-6. The fuel pressure is 58 psi +-5.
  • Posted 3 Oct 2013 12:31
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
these really are far better checked with the laptop computer with the engine running. it is a vary fast pulsed signal from the ECU that makes the injector fire, and very rarely is the problem with the injector found in the injector's coil, but rather the injector tip is what goes bad.
  • Posted 4 Oct 2013 19:59
hello thanks for the reply. do you know what the injector ohm value range should be?
  • Posted 4 Oct 2013 01:50
  • By fixnproblems
here are what the codes are:
DTC 652-6 - GM Gas Injector 2 Drive Circuit Shorted To Ground
DTC 653-6 - GM Gas Injector 3 Drive Circuit Shorted To Ground
DTC 654-6 - GM Gas Injector 4 Drive Circuit Shorted To Ground
DTC 656-6 - GM Gas Injector 6 Drive Circuit Shorted To Ground
Possible causes are:
- Injector Driver Circuit Short To Ground
- Shorted Injector Coil
- Injector Driver Module Failure
- Functional Failure in Controller
good luck
  • Posted 3 Oct 2013 21:05
  • Modified 3 Oct 2013 21:05 by poster
Toyota 8FD45
Hoist Liftruck P360-48
St. Louis, MO, United States
Ottumwa, IA, United States
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Dwight Klappich Dwight Klappich
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Executive director, NT WorkSafe
Chief executive, Logistics UK
Toyota 8FD45
Toyota 8FD45
