F34 Error- Caterpillar / DP30NT
Hello ,
Caterpillar Diesel Forklift is Showing Error F34 and Found the Transmission Speed Sensor Faulty (Wire Damaged ). I had Replaced with new one , the machine is working Smoothly but the Error Code is Still there and its blinking. I had tried Pedal Dance to Delete the Error Code but failed. After I had removed the battery for one over night but still Same Complaint.
  • Posted 22 Sep 2013 16:19
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
lishoythomas619@gmail.com
I have te same problem
Where this sensor is fixed
  • Posted 13 Feb 2021 22:30
  • By marantonious
  • joined 19 Jun'18 - 48 messages
  • kuwait, Kuwait
Marc ANTONIOUS
lishoy,
generally when the faulty component is repaired the fault code should clear itself. On occasion though i have seen where the code gets hardset in the ECM and has to be cleared with a handset or pc.
And also consider that the part could be faulty out of the box.
back to the troubleshooting board as one would say :o)
hook your service tool or pc back up and see whats going on
  • Posted 22 Sep 2013 23:06
Mobicon 2T
Maxlion MTF25-60-2WD
