If you need a part manual please
contact to my e-mail using code
(1993123 sing ) as subject.
What was wrong with it in the end then?
I don't have access to any part's books for this machine, sorry.
Dear Sir
Thanks a lot for your advice the unit now is running well now.
but i got second problem to order the parts because i dont have this part book for this unit.
if you have can you send me the part book for this unit sir?
many thanks for your help.GBU
Just remember to give the cab a wobble BEFORE you manually pull it over, the bolts that secure the tilting cab hinges to the chassis are known to come undone & also fall out.
Dear Sir
Many Thanks For Your Advice right now iam on the way to the truck which is in this problem.i will confirm to you later.after running your advice and info for the result.
E107 = Main contactor K10 does not close when the truck is started and the emergency switch is inactive.
Check the battery is in good condition, no dead cells or damaged cell straps etc.
Check the truck's battery harness isn't damaged by being crushed behind the battery - happens pretty easily on these older Reflex.
Tilt the cab over, stick the safety clip in the ram ( safety clip will be found clipped to the cab valve inside )
Disconnect the battery, check / clean the K10 contactor tips & check the electrical connectors.
Check the F62 fuse inside the motor compartment in the fuse block - 10 amp
A5 card under the armrest ( lift the cushion then remove the wing nut to get the panel of, check wire 23 which is pin 808 on the card ( the plugs are numbered ) - there should be +48 volts DC there when contactor pulled in.
