code 24 clark ecg25 sn ecg358-001666859 hd
I have a clark with code 24, control card is IC3645LXCD1-JQ, may I use normal codes troubleshooting sheets to solve it? I´ve changed F-R contacts tips but the problem persist, any idea?
Thank´s for your help
Regards
  • Posted 16 Jul 2013 09:20
  • By luismario_z
  • joined 7 Aug'08 - 14 messages
  • Jalisco, Mexico
servicio@grupozamsa.com
Thanks for your help¡¡
I´ve changed the complete F-R contactor and the code was cleared.
Problem with traction motor was the original. There was a lot of sulphate and dust in the armature.
Thanks again¡¡¡¡
  • Posted 20 Jul 2013 09:29
  • By luismario_z
  • Jalisco, Mexico
always you change the FW/RW contactors
check it the coils voltage!!!!!
the right voltage for the coils in all ev systems is 24, if you put another voltage, maybe don't work.
if this not the problem, check the microswitchs in, brake, parking brake, FW/RW selector lever, and the accelerator.... but, may be if you check what voltage missing (-) or (+) putting voltage direct in the coil at the same time you select one or another direction.
best regards
  • Posted 19 Jul 2013 12:22
  • By raul_s
  • joined 17 Jun'10 - 134 messages
  • San Luis Potosi, Mexico
Possible when changing out tips you tightened the tensioner spring to tight and this is leading to tip stand off. If contactor is old then i suggest to do as edward stated.
  • Posted 17 Jul 2013 09:21
  • By RCAV8TOR
  • Alabama, United States
it is most likely that the piece the tips ride on (correctly called the contactor armature) has lost the guide pin or the insulators are wearing out causing something to catch. you should replace the entire contactor assembly.
  • Posted 16 Jul 2013 20:03
  • Modified 16 Jul 2013 20:05 by poster
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
Neutron stars, the remnants of supernova explosions, have such extreme density that a tablespoonful of their material would weigh over 1 billion tons on Earth.
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
