code 19
truck runs normal but has wrench light and sound alarm when it has this code pop up (intermittently). can someone define the code for me?
  • Posted 10 Jul 2013 01:32
I have also seen key switches, main contactors, and some times epo switches cause this codes. I have installed a capacitor to help with static electricity on these trucks.
  • Posted 12 Jul 2013 11:58
  • By rogeriwt
The code 19 relates to an under voltage at the traction controller. With a battery problem you would also see a code 32 for the lift controller. Are you having to charge the battery shortly after this happens? If so you may need to have the BDI cut out adjusted to keep the battery from getting low to set this code.
  • Posted 12 Jul 2013 11:37
  • By Bulldog965
  • joined 15 Oct'09 - 63 messages
  • Indiana, United States
Richard
Maxlion FB30LI
Taylor TT300
REPOWERTEK Inc
