crown 50fctt-188 serial 9a115662
no codes forward contactor closes card hum seems loud rev works fine normal hum.if you plug rev to fwd motor continues to drive in reverse. both fwd rev contacts open/close nomally during plug cycle.all recs/filters test good motor maybe? swapped tb5/6 same fault no fwd. any help thanks in advance
  • Posted 14 Jun 2013 11:42
  • By rollover
  • joined 25 Feb'09 - 15 messages
  • British Columbia, Canada
I would first get the battery out and clean all the corrosion from under the battery compartment, replace any power cables that seem to have been sitting in the corrosion, and check to insure all the cables or in their correct locations. you may have a power cable in the wrong spot, or so much corrosion that it can carry enough power to turn the motor, but my bet is cables on the controller wrong. bad contact tips would never cause this, you would get a code rather than try and run.
  • Posted 15 Jun 2013 21:19
I would be thinking contactor tips
either rebuild contactor or replace
  • Posted 15 Jun 2013 09:35
  • By crownie
  • Victoria, Australia
GemOne
UN Forklift FGL18T
Enforcer FLBAXT25
GemOne
