Overheating
This truck is running for about an hour before servearly overheating? I have checked for leaks non found I have replaced the thermostat as old one was faulty. Refilled system with 50/50 coolant but truck still overheating? I'm going to pressure test in morning to see how system is? Rad is in good condition as are pipes? Am I missing something? Newly outta time so please be gentle haha
  • Posted 12 Jun 2013 05:40
  • By suchy1977
  • joined 5 May'13 - 22 messages
  • humberside, United Kingdom
You cant beat experience! and me been a newbie outta time will find these things out i suppose with time. Thanks for the replies ppl
No doubt i will be posting again ;-)
  • Posted 1 Aug 2013 23:02
  • By suchy1977
Back in the olden days we used to say that a clogged radiator with insufficient flow of coolant through the tubes would cause visible collapsing of the lower radiator hose (due to cavitation suction on the inlet pipe of the water pump).
I doubt that would apply now that the newer applications utilize a blending thermostat situated in the lower hose.
  • Posted 1 Aug 2013 14:52
  • By L1ftmech
  • Tennessee, United States
Took the radiator in for pressure testing and found the core had collapsed. I took some advice from a friend who said if i could poor water through with the bottom hose off and the water came through well the rad was GOOD! How wrong he was! Just go's to show you cant beat a good pressure test.
  • Posted 1 Aug 2013 06:15
  • By suchy1977
Thanks for reply Kev t. The rad was blocked up with dust, I blew it out with an air line and replaced the water pump as this was on its way out. However i'm still having issues with the overheating but not as often now. The gearbox was covered with about 2" of dust i have cleaned the dust of, i'm guessing that could of been a major factor in the overheating as the radiator has oil cooling built into it. the fan belt is at the correct tension, head gasket looks fine but am going to do a compression test next just to eliminate that but i can't see any tell tale signs of the gasket failing?
regards suchy1977
  • Posted 11 Jul 2013 19:41
  • By suchy1977
Possible head gasket issue???Do a compression check and see what that shows....Fan belt tight and not slipping on the pulley? Radiator not plugged with dust,dirt,debris???
  • Posted 12 Jun 2013 09:02
  • Modified 12 Jun 2013 09:04 by poster
  • By kevin_t
MAXAM Tire, Inc.
Philadelphia, United States
Prospect CT, United States
Dayton OH/Cincinnati OH, United States
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
ASSET FINANCE
Nov 2025
