BT SPE125 Max lift calibration
Hi,
I am working at the above truck and I am getting c30 fault when lifting a light pallet. I have checked everything and now think that it just needs calibrated. Does anyone know the parameter for calibration and the process to follow?
I have a can key
Cheers
  • Posted 17 May 2013 02:06
  • By andrew_p
  • joined 7 Nov'12 - 23 messages
  • Co. Antrim, United Kingdom
Hello Gary.
See your email
Best regards, Laci
  • Posted 5 Jun 2013 02:49
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Hi,
i have problems with a SPE160, any chance you have a manual for this truck.
Regards.
  • Posted 5 Jun 2013 02:15
  • By gary_f
  • joined 8 Aug'09 - 57 messages
  • Malaga, Spain
I've never had the pleasure of working on a SPE.
Sent you the same SPE info plus an added bonus of some RRE Ergo info.
  • Posted 22 May 2013 07:22
  • By Forkingabout
  • england, United Kingdom
Hello Forkingabout
I have a similar model.Problem is mast interchange moment not smooth change.Check S33 switch via truckcom software.It is correct input.How to solved this problem
Model-SPE160
S/NO-930631/2006
Software pakage-230881-002
Thanks
  • Posted 22 May 2013 00:48
  • By kmj_f
  • joined 12 Jan'13 - 31 messages
  • COLOMBO, Sri Lanka
Should be something useful waiting in your email inbox.
  • Posted 17 May 2013 03:42
  • By Forkingabout
Done! Brilliant thank you
  • Posted 17 May 2013 03:25
  • By andrew_p
Stick your email in your profile & ill send you the info, the weight calibration on these is far to longwinded & involved for me to type it all out.
  • Posted 17 May 2013 03:19
  • By Forkingabout
Muncie, IN, United States
