YELLOW STUFF IN HYDRAULICS
I had a RRS30 when you would reach it in it would drift out 12". Troubleshooting in the aux system only revealed some yellow fibrous like material in the CV and I even found an o-ring. I cleaned the system flushed out all the oil through the reach system and replaced all the filters of which there was none of the contamination. I also found some metal bits. Is there anyone who has or may have seen the same thing. I am next going to disassemble the pump and reach valve.
Thanks
  • Posted 16 May 2013 01:47
  • By joe_r
  • joined 1 May'13 - 9 messages
I repacked both reach cylinders and the tilt cylinder. I also put new seals on all of the solenoid valves as well as the check valves
  • Posted 16 May 2013 03:42
  • By joe_r
Sounds like maybe the seals blew or something broke in one of the reach cylinders.
  • Posted 16 May 2013 03:22
Muncie, IN, United States
