Clark ECG-30
Have an unusual situation ( I think ), the unit has posted on it's data plate the battery voltage is 36 Volt yet battery & charger for lift is 48 Volt. Lift was bought off ebay about 2 years ago & now battery showing signs of needing replacement. Not sure of which battery to quote 48 V or 36 V & charger- any help would be appreciated.
  • Posted 9 May 2013 05:54
  • By bbforks
Thanks guys very much. I wish the Clark tech that was out last year would have presented the voltage issue this way.
  • Posted 9 May 2013 23:07
  • By bbforks
Stam is right. The controller has a 36/48 volt setting that is programmed in by the hand set. I would quote out what is in the truck.
  • Posted 9 May 2013 12:17
  • By rogeriwt
i thought that truck had a ge sx system in it. i have only seen one once. from what i remember it is 36/48 volt if it is a ge system you could check the voltage setting parameter with the handset
  • Posted 9 May 2013 09:09
  • By stam
Yes- everything matches. What's involved in converting from 36 to 48 V ? I had to replace the brain about a year ago (flight systems rebuild) - the local Clark dealer was needed to program it. I purchased the brain based on the model & serial #'s- I assume the brain was set up for 36 V- the Clark guy didn't know if running the truck on 48 V would harm the brain or not- so far so good.
  • Posted 9 May 2013 07:36
  • By bbforks
Does the Data plate Serial number and the serial number stamped on the truck match???
sounds like it might of been converted at some point.....if the numbers are matching.....
  • Posted 9 May 2013 07:23
  • By kevin_t
UN Forklift FBR25NQC3
UN Forklift FD30-35T
Deborah Baker Deborah Baker
