P5000 transmission pressure and test points
Hello!
Can someone help me with information on transmission pressures and test points on a CAT P5000 with serial AT 3400517?
Customer says he overhauled the transmission but truck does not move.
Thanks,
OB1
  • Posted 5 May 2013 02:53
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Cheers!
Thanks swoop223! I'll take a look at the info you sent me.
Regards,
OB1
  • Posted 14 May 2013 00:33
  • By ob1kenobi
Cheers!
ob i sent you some specs on the powershift trans
it should help you check pressures and show you a couple of other things
good luck
  • Posted 13 May 2013 20:44
if it has the single solenoid pneumatic mitsu transmission check main pressure tap marked M should be about 150 psi, then check d tap with trans in forward 150 psi 0 psi neutral 150 psi reverse if it has a dual solenoid cushion transmission readings should be the same but forward and reverse have their own pressure taps labeled f and r respectively. on a single solenoid style trans check the last chance solenoid strainer on the drivers side of the valve body with an allen head screw near the solenoid.
  • Posted 13 May 2013 11:57
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
Is it possible for pressure to read "0" at the control valves?
  • Posted 13 May 2013 04:52
  • By ob1kenobi
Thanks swoop223. Sorry for the bad serial. The correct one is:
P5000R
Serial : AT3502640
If you have any info you can supply me with, you may send it to obandy01 at hot mail
Best regards,
OB1
  • Posted 9 May 2013 06:59
  • By ob1kenobi
Cheers!
thats not a P5000 serial number
a P3000 or P3500 maybe
as for getting any information to you how is anyone going to accomplish that? no way to get it to you :o)
  • Posted 7 May 2013 21:04
SMV (Konecranes) 4538CCX4
Terberg YT220
Lift Technologies Inc.
Terberg YT220
Muncie, IN, United States
Deborah Baker Deborah Baker
