Yale GLP25VX with joystick
Is it possible to convert a machine with joystick to mini levers. I have tried plugging a mini lever control box into the truck but i geta can bus fault. Is there a setting in the dash that can be changed? Any help apprieciated.
  • Posted 19 Apr 2013 20:32
  • By Leon_W
  • Tyne & Wear, United Kingdom
Showing items 1 - 20 of 20 results.
Through service password? Ill look into it tomorrow, thanks!
Any ideas on latest version number, or full serial required?
  • Posted 4 Jun 2019 04:55
  • By andy_j
  • joined 16 Aug'12 - 38 messages
  • Uk, United Kingdom
Andy_w_jones@hotmail.co.uk
if your truck has up to date software you can switch between 3-4 lever MLM or joystick via the display
  • Posted 4 Jun 2019 03:35
  • By stackerhacker
  • joined 2 Mar'18 - 87 messages
  • glasgow, United Kingdom
Ok thanks.
  • Posted 1 Jun 2019 07:15
  • By andy_j
It is a add on to PCST. It is actually a stand alone program.
  • Posted 1 Jun 2019 07:13
  • By BREWSKI
Would that be done through pc service tool or different?
  • Posted 1 Jun 2019 06:11
  • By andy_j
No jumper available. You can request a new CDF file for three lever only. You will need to get this installed by a Yale tech.
  • Posted 1 Jun 2019 06:02
  • By BREWSKI
Same issue with number 4, but no 4th lever fitted. Fitting an extra lever clears the fault but an expensive work around, does anyone know if there is a jumper available? If so part number at all?
  • Posted 1 Jun 2019 01:26
  • By andy_j
not sure, but you may need a jumper plug into the 4th lever harness plug.
  • Posted 30 Apr 2013 21:08
No 4th lever but I think You can plug one into that board.they can give out all sorts of random code's when they fail.
  • Posted 30 Apr 2013 04:13
  • By kevin_k
every thing works fine but it throws an error code up about the 4 mini lever is OORL but there isn't a 4th mini lever fitted and its not turned on through the dash. Its been a strange one.
  • Posted 30 Apr 2013 03:03
  • By Leon_W
Not available separate to my knowledge. I've seen them boards fail a couple of times.
  • Posted 30 Apr 2013 03:00
  • By kevin_k
There was a problem with the PCB inside of the MLM. Is this available seperately? i can't find a part no. for the PCB, it has got the number 251941A but that isn't recogonised by TVH.
  • Posted 30 Apr 2013 02:55
  • By Leon_W
VSM need calibration after settings!
Regards
  • Posted 24 Apr 2013 15:47
  • By petko_t
  • joined 28 Sep'10 - 37 messages
  • Sofia, Bulgaria
p.troanski@abv.bg
Petko thank you for the info. I found a setting in the dash options for input device. i couldn't see this option anywere in the manual.It worked straight away. i have got an error code 523249-4 now, some sort of lever 4 input error. i think it is just a parameter needs changing.
  • Posted 22 Apr 2013 23:44
  • By Leon_W
VSM need setting and calibration
Regards
  • Posted 22 Apr 2013 23:22
  • By petko_t
  • Sofia, Bulgaria
p.troanski@abv.bg
Hi, Leon,
Ive looked at my notes and Ive come to the conclusion that the mini pod and joy sticks should be interchangable, is the pod you are using to substitute the joystick with new or second hand Im thiking canio problem possibly a broken wire in the pod or connector, other than that you should be able to fit the pod and set it up through the dash display.
Regards Titus
  • Posted 22 Apr 2013 21:04
  • By Titus
  • joined 6 Jul'10 - 185 messages
Hello,
Send me mail.
Regards
  • Posted 22 Apr 2013 19:14
  • By petko_t
  • Sofia, Bulgaria
p.troanski@abv.bg
I have already got the part no. What else needs to be done to allow the mini levers to work. I get a can bus error.
  • Posted 22 Apr 2013 17:05
  • By Leon_W
Mini lever module MLM p/no 580089967
  • Posted 22 Apr 2013 16:55
  • By petko_t
  • Sofia, Bulgaria
p.troanski@abv.bg
I'm not certain if you can do it with a GLP but you can do it with the Yale MR range, you may need a harness supplement or conversion to suit mini levers, I don't see why it should not be possible,
Regards Titus
  • Posted 19 Apr 2013 20:42
  • By Titus
edition #1235 - 19 June 2025
SMV (Konecranes) 16-1200C
Toyota 3FD100
Manitou MH25-4
Mitsubishi FGE35AT
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
