Toyota - 7FGCU25 - 4Y ECU - no start
Hello, Checked for codes on the 4-pin plug - has a constant TWC flash = systems OK ??? Good fuel. good spark....any thoughts??? Sry ECS 4Y e-mail
prenticelift at gmail dot com
  • Posted 13 Apr 2013 04:36
  • Modified 13 Apr 2013 06:30 by poster
  • By Prentice
Hello Edvard. Any problem with your email adress. Write you shortly for my adress.
best regards, Laci
  • Posted 27 Apr 2013 17:56
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Ed did you get any tech information???
  • Posted 27 Apr 2013 04:45
  • By Prentice
Laci or Prentice, could I also beg a copy of that information, I just had a 4y-ecs truck that I had to take to the local Toyota dealer's shop since the road tech made 3 trips to our shop and could not give a quote for what it would cost to repair to get running, the dealer charged 15 hours to redo the same tune up we had done, and no further explanation of what the problem really was.
I sure could of used this information back in November 2012, thanks in advance.
  • Posted 24 Apr 2013 20:09
Got It......... Was getting to much fuel. Valve not seated correctly. Also had bad throttle pot. Many Thanks to all who helped. Great information
  • Posted 24 Apr 2013 06:07
  • By Prentice
That was going to be my next suggestion. Hopefully t is an easy fix.
Good Luck.
  • Posted 18 Apr 2013 07:01
  • By rogeriwt
It is LPG. Yes I have had that issue in the past. It was one of the first things I checked. I have seen the shielded wire with LPS units. I recieved some great Information from another person. I did notice the elec Throtle Control (carb) not responding.....running voltage tests and i think it might be seized.We will keep you posted. Thanks for the reply
  • Posted 17 Apr 2013 21:59
  • By Prentice
Is it gas or lp? I have seen the tach signal wire **** out of the distributor going to the ecu break. I would check that. Be careful when repairing the wire because it is shielded and if grounded it doesn't work.
  • Posted 17 Apr 2013 12:52
  • By rogeriwt
Hello Prentice.
See your email.
Best regards, LACI
  • Posted 13 Apr 2013 19:24
  • By LACI
  • Serbia
